I have a switch called "DWH" that I have a Triggered Rule schedule to turn on 5:00 AM on weekdays and 8:00 AM on weekends, if the virtual switches Vacation & Holiday are off. It works perfectly.
I have a second Trigger that when DWH turns on, it is supposed to turn it off after a delay of 60 minutes. This does not run.
Why not? Here are the relevant screen caps from Rule Machine:
Or you could add the delayed off 60 minutes to the Select Actions for False of the first rule (unless you need this as a trigger to be used for multiple rules.)
No!! This won't change anything. Both the trigger and the rule are fired by the exact same event.
@aaiyar All of the suggestions above are misleading, and not getting to the real issue: Why doesn't your trigger work. It certainly should work! Have you looked at the logs? The DWH 60 mins max Trigger will log the events it sees for DWH. So that's the place to start. Also, look at the device events for DWH. What kind of device is this?
I've always wondered why all I could find was "between two times" and not at a certain time, I was always trying to create a rule, I never looked under "Create a Trigger" for it. Thanks.
