Nothing I can think of. The baby monitor is 2.4Ghz I have some 3210-Ls that I did add the repeater(Zwave side) to the network. Could that be the issue?
Could be.. I heard there were some firmware versions that made bad repeaters...
What brand is the repeater ?
Lowes Iris V2
Ah, I was just asking about the exact same thing yesterday. Was hoping @bcopeland had a response for it. I get like 30 of the same messages when I either change the color or the color temperature and that slows down my hub and the bulb itself.
OK. I don't know if this was the issue or not. but I was unable to pair the z wave on my two Outlets. But I did power cycle them...Then I spotted this Door Chime repeater next to the doorbell for the carport. (I have never used this repeater or doorbell really. It is wired into a Sage button. )
I ripped out the batteries and things look much better. However the bulb is still super chatty.
dev:672020-05-03 06:53:55.164 pm infoK-Dining Room: Basic report received with value of off (0)
dev:1112020-05-03 06:53:54.634 pm debugSwitchMultilevelReport(value:0)
dev:1112020-05-03 06:53:54.630 pm debugparse:zw device: 0D, command: 2603, payload: 00 , isMulticast: false
dev:1002020-05-03 06:53:53.204 pm infoK-Carport Switch: Button 1 was held
dev:1112020-05-03 06:53:52.475 pm debugSwitchMultilevelReport(value:99)
dev:1112020-05-03 06:53:52.431 pm debugparse:zw device: 0D, command: 2603, payload: 63 , isMulticast: false
dev:672020-05-03 06:53:52.384 pm infoK-Dining Room: Button 1 was held
dev:1112020-05-03 06:53:52.287 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 06:53:52.259 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:green, colorComponentId:3, value:245)
dev:1112020-05-03 06:53:52.255 pm debugparse:zw device: 0D, command: 3304, payload: 03 F5 , isMulticast: false
dev:1112020-05-03 06:53:52.244 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 06:53:52.185 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 06:53:52.164 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:red, colorComponentId:2, value:255)
dev:1112020-05-03 06:53:52.138 pm debugparse:zw device: 0D, command: 3304, payload: 02 FF , isMulticast: false
dev:1112020-05-03 06:53:52.113 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:coldWhite, colorComponentId:1, value:0)
dev:1112020-05-03 06:53:52.108 pm debugparse:zw device: 0D, command: 3304, payload: 01 00 , isMulticast: false
dev:1112020-05-03 06:53:52.051 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 06:53:52.039 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 06:53:52.032 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 06:53:52.028 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 06:53:51.991 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:blue, colorComponentId:4, value:0)
dev:1112020-05-03 06:53:51.987 pm debugparse:zw device: 0D, command: 3304, payload: 04 00 , isMulticast: false
dev:1112020-05-03 06:53:51.962 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 06:53:51.916 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:green, colorComponentId:3, value:245)
dev:1112020-05-03 06:53:51.912 pm debugparse:zw device: 0D, command: 3304, payload: 03 F5 , isMulticast: false
dev:1112020-05-03 06:53:51.875 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 06:53:51.842 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:red, colorComponentId:2, value:255)
dev:1112020-05-03 06:53:51.837 pm debugparse:zw device: 0D, command: 3304, payload: 02 FF , isMulticast: false
dev:1112020-05-03 06:53:51.817 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 06:53:51.765 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:red, colorComponentId:2, value:255)
dev:1112020-05-03 06:53:51.760 pm debugparse:zw device: 0D, command: 3304, payload: 02 FF , isMulticast: false
dev:672020-05-03 06:53:51.749 pm infoK-Dining Room: Button 1 was pushed
dev:1112020-05-03 06:53:51.637 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 06:53:51.607 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:blue, colorComponentId:4, value:0)
dev:1112020-05-03 06:53:51.597 pm debugparse:zw device: 0D, command: 3304, payload: 04 00 , isMulticast: false
dev:1112020-05-03 06:53:51.540 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 06:53:51.534 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 06:53:51.513 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:red, colorComponentId:2, value:255)
dev:1112020-05-03 06:53:51.507 pm debugparse:zw device: 0D, command: 3304, payload: 02 FF , isMulticast: false
dev:1112020-05-03 06:53:51.503 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:green, colorComponentId:3, value:245)
dev:1112020-05-03 06:53:51.488 pm debugparse:zw device: 0D, command: 3304, payload: 03 F5 , isMulticast: false
dev:1112020-05-03 06:53:51.345 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 06:53:51.329 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 06:53:51.305 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 06:53:51.298 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 06:53:51.234 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:coldWhite, colorComponentId:1, value:0)
dev:1112020-05-03 06:53:51.218 pm debugparse:zw device: 0D, command: 3304, payload: 01 00 , isMulticast: false
dev:1112020-05-03 06:53:51.179 pm debugsetLevel(100, 1)
dev:1112020-05-03 06:53:51.124 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 06:53:51.076 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 06:53:51.040 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 06:53:51.036 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:blue, colorComponentId:4, value:0)
dev:1112020-05-03 06:53:51.030 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 06:53:51.026 pm debugparse:zw device: 0D, command: 3304, payload: 04 00 , isMulticast: false
dev:1112020-05-03 06:53:50.843 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 06:53:50.833 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 06:53:50.768 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:green, colorComponentId:3, value:245)
dev:1112020-05-03 06:53:50.759 pm debugparse:zw device: 0D, command: 3304, payload: 03 F5 , isMulticast: false
dev:1112020-05-03 06:53:50.706 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:red, colorComponentId:2, value:255)
dev:1112020-05-03 06:53:50.685 pm debugparse:zw device: 0D, command: 3304, payload: 02 FF , isMulticast: false
dev:1112020-05-03 06:53:50.398 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 06:53:50.389 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 06:53:50.376 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:coldWhite, colorComponentId:1, value:0)
dev:1112020-05-03 06:53:50.369 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 06:53:50.353 pm debugsetColorTemperature(2700)
dev:1112020-05-03 06:53:50.342 pm debugsetLevel(100, 1)
dev:1112020-05-03 06:53:50.324 pm debugparse:zw device: 0D, command: 3304, payload: 01 00 , isMulticast: false
dev:1112020-05-03 06:53:50.312 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 06:53:50.123 pm debugsetColorTemperature(2700)
dev:1002020-05-03 06:53:49.816 pm infoK-Carport Switch: Button 1 was pushed
There is no getting around it being chatty.. But what you shouldn't see is a bunch of repeats of the same message..
Each colorComponent has to be sent as a separate message, and since they didn't support V3 there is no target so I had to send request again after delay to support fadeDuration which makes nice smooth transitions rather than jerky jumps.. Plus the fact that if one of the color components doesn't change values it won't send that component out in the automatic replies.. A few quirks like that that caused a bit more talking than I would normally like...
But if your mesh is behaving .. it shouldn't be an issue.. I send colorTemperature to 27 bulbs at the same time and have no delays..
Are you getting repeated identical packets too?
Your log looks much better though.. The repeats are gone
I am. I had 6 messages for ColorComponent0, 10 messages for ColorComponent1, 8 for ColorComponent2, 7 for ColorComponent3 and 1 for ColorComponent4.
So a total of 26 messages when only 5 where needed
My bulb is about 10 ft from the HE hub. However, I have almost 15 Inovelli red on/offs and dimmers in between them.
So it sounds like you are having mesh issues too..
How far is your hub
Do you have adequate repeaters in place?
Any interference sources? 900Mhz cordless phones, baby monitors, doorbells?
you have 15 switches between your hub and this bulb at 10 ft?
Physically I mean. A bunch of 3 and 4 gang switches... I'll check the mesh now.
10ft line of sight?.. I had someone tell me recently their hub was 10 ft away through a floor..
I guess I'm that guy! There's a couple of walls in between (the hub is in the living room while the bulb is in the bedroom)
Ok.. That’s not 10 ft
Yup. Let's say about 30 feet. No direct line of sight.
But if you have enough repeaters in place, along the path, it should be fine..
If you have the repeater infrastructure.. I would do a z-wave repair, and look for sources of interference..
