Pressed button on to turn on carport switch. Turned off the kitchen light. Turned off the bulb. Resulted in this
dev:1112020-05-03 04:44:01.358 pm debugSwitchMultilevelReport(value:0)
dev:1112020-05-03 04:44:01.353 pm debugparse:zw device: 0D, command: 2603, payload: 00 , isMulticast: false
dev:692020-05-03 04:44:00.249 pm infoK-Kitchen Switch: Switch Binary report received with value of off
dev:692020-05-03 04:44:00.219 pm infoK-Kitchen Switch: Switch Binary report received with value of off
dev:692020-05-03 04:44:00.158 pm infoK-Kitchen Switch: Switch Binary report received with value of off
dev:6752020-05-03 04:44:00.009 pm infoK-UnderCabinet 2.0 level is 100%
dev:692020-05-03 04:43:59.965 pm infoK-Kitchen Switch: Switch Binary report received with value of off
dev:692020-05-03 04:43:59.290 pm infoK-Kitchen Switch: Switch Binary report received with value of off
app:3942020-05-03 04:43:59.173 pm infoAction: Wait for condition: K-Sink Motion, K-Kitchen Motion all inactive FALSE
dev:692020-05-03 04:43:59.155 pm infoK-Kitchen Switch: Switch Binary report received with value of off
dev:692020-05-03 04:43:59.110 pm infoK-Kitchen Switch: Switch Binary report received with value of off
app:3952020-05-03 04:43:59.026 pm info!Kitchen Motion 3.1 Triggered
app:3952020-05-03 04:43:58.999 pm info!Kitchen Motion 3.1: K-Occupied Switch switch on
app:3942020-05-03 04:43:58.859 pm infoAction: Cancel Delayed Actions
app:3942020-05-03 04:43:58.824 pm infoAction: Dim: K-UnderCabinet 2.0: 100
dev:5902020-05-03 04:43:58.810 pm infoK-Occupied Switch was turned on
app:3942020-05-03 04:43:58.794 pm infoAction: On: K-Occupied Switch
app:3942020-05-03 04:43:58.786 pm infoAction: IF (Mode is Home(T) [TRUE]) THEN
dev:692020-05-03 04:43:58.741 pm infoK-Kitchen Switch: Switch Binary report received with value of off
dev:692020-05-03 04:43:58.675 pm infoK-Kitchen Switch: Switch Binary report received with value of off
app:3942020-05-03 04:43:58.630 pm info!Kitchen Motion 3.0 Triggered
dev:692020-05-03 04:43:58.600 pm infoK-Kitchen Switch: Switch Binary report received with value of off
dev:5912020-05-03 04:43:58.463 pm infoK-Kitchen Motion is active
dev:1112020-05-03 04:43:58.367 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:58.361 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:58.356 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 04:43:58.185 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:58.179 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:58.175 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 04:43:57.872 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:57.867 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:57.862 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:692020-05-03 04:43:57.815 pm infoK-Kitchen Switch: Switch Binary report received with value of off
dev:1112020-05-03 04:43:57.767 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:57.761 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:57.757 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 04:43:57.673 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:57.659 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:57.655 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 04:43:57.619 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:57.596 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:57.587 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:57.580 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 04:43:57.571 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:57.563 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 04:43:57.529 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:57.525 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:57.515 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 04:43:57.508 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:57.501 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:57.496 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 04:43:57.439 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:57.433 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:57.429 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:692020-05-03 04:43:56.918 pm infoK-Kitchen Switch: Switch Binary report received with value of off
dev:692020-05-03 04:43:56.844 pm infoK-Kitchen Switch: Switch Binary report received with value of off
dev:692020-05-03 04:43:56.799 pm infoK-Kitchen Switch: Switch Binary report received with value of off
dev:1112020-05-03 04:43:55.773 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:55.766 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:55.762 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 04:43:55.527 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:55.519 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:55.514 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 04:43:53.527 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:53.520 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:53.514 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:5752020-05-03 04:43:53.155 pm infoM-Bath Door battery is 89%
dev:1112020-05-03 04:43:53.071 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:53.065 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:53.060 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 04:43:52.981 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:52.974 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:52.969 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 04:43:52.793 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:52.787 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:52.782 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 04:43:52.600 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:52.592 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:52.587 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 04:43:52.532 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:52.525 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:52.521 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:692020-05-03 04:43:52.392 pm infoK-Kitchen Switch: Switch Binary report received with value of off
dev:692020-05-03 04:43:52.320 pm infoK-Kitchen Switch: Switch Binary report received with value of off
dev:1112020-05-03 04:43:52.256 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:52.245 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:52.239 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 04:43:52.205 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:52.196 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:52.191 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:692020-05-03 04:43:50.141 pm infoK-Kitchen Switch: Switch Binary report received with value of off
dev:5852020-05-03 04:43:49.963 pm infoG-Guest Room Motion adjusted temperature is 72.05°F [sensor value 72.05]
dev:1112020-05-03 04:43:48.908 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:48.901 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:blue, colorComponentId:4, value:0)
dev:1112020-05-03 04:43:48.895 pm debugparse:zw device: 0D, command: 3304, payload: 04 00 , isMulticast: false
dev:1112020-05-03 04:43:48.824 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:48.818 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:green, colorComponentId:3, value:245)
dev:1112020-05-03 04:43:48.813 pm debugparse:zw device: 0D, command: 3304, payload: 03 F5 , isMulticast: false
dev:1112020-05-03 04:43:48.741 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:48.735 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:red, colorComponentId:2, value:255)
dev:1112020-05-03 04:43:48.730 pm debugparse:zw device: 0D, command: 3304, payload: 02 FF , isMulticast: false
dev:1112020-05-03 04:43:48.676 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:48.667 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:coldWhite, colorComponentId:1, value:0)
dev:1112020-05-03 04:43:48.662 pm debugparse:zw device: 0D, command: 3304, payload: 01 00 , isMulticast: false
dev:1112020-05-03 04:43:48.621 pm debugSwitchMultilevelReport(value:99)
dev:1112020-05-03 04:43:48.616 pm debugparse:zw device: 0D, command: 2603, payload: 63 , isMulticast: false
dev:692020-05-03 04:43:47.271 pm infoK-Kitchen Switch: off()
dev:1112020-05-03 04:43:47.018 pm debugSwitchMultilevelReport(value:99)
dev:1112020-05-03 04:43:47.014 pm debugparse:zw device: 0D, command: 2603, payload: 63 , isMulticast: false
dev:692020-05-03 04:43:47.009 pm infoK-Kitchen Switch: Button 1 was held
dev:1112020-05-03 04:43:44.439 pm debugSwitchMultilevelReport(value:99)
dev:1112020-05-03 04:43:44.436 pm debugparse:zw device: 0D, command: 2603, payload: 63 , isMulticast: false
dev:1112020-05-03 04:43:44.391 pm debugSwitchMultilevelReport(value:99)
dev:1112020-05-03 04:43:44.371 pm debugparse:zw device: 0D, command: 2603, payload: 63 , isMulticast: false
dev:692020-05-03 04:43:44.356 pm infoK-Kitchen Switch: off()
dev:692020-05-03 04:43:44.323 pm infoK-Kitchen Switch: off()
dev:692020-05-03 04:43:44.108 pm infoK-Kitchen Switch: off()
dev:692020-05-03 04:43:44.089 pm infoK-Kitchen Switch: Button 1 was held
dev:692020-05-03 04:43:43.949 pm infoK-Kitchen Switch: Button 1 was held
dev:692020-05-03 04:43:43.788 pm infoK-Kitchen Switch: Button 1 was held
dev:1112020-05-03 04:43:43.453 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:43.444 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:43.439 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:1112020-05-03 04:43:43.325 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:43.305 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:43.290 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:692020-05-03 04:43:43.195 pm infoK-Kitchen Switch: off()
dev:1112020-05-03 04:43:43.190 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:43.172 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:43.153 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:692020-05-03 04:43:42.900 pm infoK-Kitchen Switch: Button 1 was held
dev:692020-05-03 04:43:42.716 pm infoK-Kitchen Switch: off()
dev:692020-05-03 04:43:42.666 pm infoK-Kitchen Switch: off()
dev:1112020-05-03 04:43:42.451 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:42.423 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:42.415 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:692020-05-03 04:43:42.398 pm infoK-Kitchen Switch: off()
dev:1112020-05-03 04:43:42.333 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:42.195 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:1112020-05-03 04:43:42.180 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:692020-05-03 04:43:41.987 pm infoK-Kitchen Switch: Button 1 was held
dev:1112020-05-03 04:43:41.983 pm debugwarmWhite: 255, coldWhite: 0
dev:1112020-05-03 04:43:41.958 pm debuggot SwitchColorReport: SwitchColorReport(colorComponent:warmWhite, colorComponentId:0, value:255)
dev:692020-05-03 04:43:41.889 pm infoK-Kitchen Switch: Button 1 was held
dev:1112020-05-03 04:43:41.884 pm debugparse:zw device: 0D, command: 3304, payload: 00 FF , isMulticast: false
dev:692020-05-03 04:43:41.787 pm infoK-Kitchen Switch: Button 1 was held
dev:1112020-05-03 04:43:41.212 pm debugsetLevel(100, 1)
dev:1112020-05-03 04:43:41.092 pm debugsetColorTemperature(2700)
