While Statement & Repeat N Times Problem
I'm sure it's me but confused...
When creating a while statement...even if I have not selected a device...the repeat n times switch only gives me "volume" as a selection. I can't enter a number? I've rebooted etc...have I forgotten how this works? Same after selecting the device
Did you try filling out the "Repeat Every (Required)" section first?
I seem to recall that I had to do that before I could move forward with other options. Try putting something in the hours, minutes, and/or seconds, then see what options you get.
Note: The toggle there is for using a declared VARIABLE. So, you don't need to turn that on unless you are using a variable.
Thanks but Yes...
Try unselecting “repeat variable n times” switch.
Right, because you selected to use a variable instead of direct numeric input (and you see what is apparently your only usable variable in the dropdown). So this should indeed be the solution:
Thanks...and well duh...though it does seem a little weird to have an "on" slider there...
I must need more sleep :slight_smile:
