Good day all, I am running a C-7 with 2.3.2 F/W
I am a bit confused on the Z-wave update button and whether or not it disappears after the hub is on the latest and greatest z-wave firmware. I noted the button on the top right of the page and took that as it meant that my hub had a z-wave update for it. I selected it and then the webpage indicated it was doing something in the background and refreshed and the update button was still there. I was under the assumption that the Update button is only displayed when there is an update available and if that is the case it appears not to be updating them. I will check the version when I get home once I find the command.
Am I incorrect in my assumption?
Thank you
B
