When I try to connect to my discovered hub I get Hmmm can't find this page error. Hub is visible on my eero network
Help...or is there a customer service contact number to call???
Also I am able to control devices connected via Alexa...trying to add another device that dropped and control locke ie add access codes etc.
the most common answer to this symptom is that the IP Address of the hub changed. It's often suggested that you reserve an address for the hub in your Router. That way, each time the Hub gets the same address.
Use http://findmyhub.hubitat.com/
what address should I reserve in my router?
