When going to the drivers code, takes forever to load
I'm on 2.4.0.151. When I click on one of the drivers in the "drivers code" section, it takes like over a minute to load one of them. Anyone else having this problem? Or could it be my custom driver for LiteTouch having a problem and taking up a bunch of CPU?
How many custom drivers/apps code do you have loaded?
What hub model?
Also, on very complicated code it does take it a bit to open and to save. But more simple code should be a lot faster.
Yes, quite possible, I did post a reply over on your thread for that as well.
Check the logs and App/Device stats pages, it will show you if anything is running out of control. You would probably also be getting errors in the logs.
