Just wondering how you guys do it efficiently. (comparing notes)
DEVICES
Kitchen Ceiling Lights
Kitchen Sink Lights (led strip for the kitchen sink)
Motion Detector by the Kitchen sink
Desired Behavior:
#1
If motion is detected, TURN ON -> Sink Lights
And then Turn OFF Sink Lights after 30 seconds of NO MOTION
#2 (similar to #1 but with conditions)
And then Turn OFF Sink Lights after 30 seconds of NO MOTION ---> BUT, only if Kitchen Ceiling Lights are NOT ON, else, keep Sink Lights ON for another 30 seconds, and so on.
Basically, for this one, I want the sink lights to turn on if someone uses the sink, and turns off after 30secs, but only if the main ceiling lights are also off.
Here's how I would write your two rules in Rule Machine
Rule 1
Trigger Events
KS Motion is active
Actions to Run
On: KS Lights
Wait for events: KS Motion inactive an stays that way for: 0:00:30
Off: KS Lights
Rule 2
Trigger Events
KS Motion is active
Actions to Run
On: KS Lights
Wait for Expression: KS Light is off --> duration: 0:00:30
Off: KS Lights
The Rule 2 Waits could be written as a single Wait but I think this shows the logic better as written.
Room Lighting. Note you need to know your motion sensor timeout. Some are configurable, some are not. Any delay you configure is in addition to the timeout of the sensor itself.
Ok about this. I wanted to use this App (Room Lighting) but I am under the impression that the more Apps installed on the hub, the more resource is spent, so I thought "if i could achieve what I want with Rule Machine, I better stick w/ it to keep the hub light on its feet" - is this an OK way of thinking bout this?
I see. I've not played with SA, ill take a look. And i don't mind raising the wait to 1minute instead of 30secs... Room Lightings App also can't do < 1min, i just found out now.
This is true… but every rule is an instance of a Rule Machine app. The parent app you use to create a new instance doesn’t consume any resources. Same for room lighting. I doubt there’s any significant difference in resource usage with the same automation being done with either, or simple automation.
The box accepts a decimal number. Try 0.5, you should get 30 seconds. Also mind the sensor’s own delay.
