What is the best way to mimic Hue Dimmer Switch with Pico Remote?
Here is what I came up with to somewhat mimic the Hue Dimmer switch. I have my Hue bulbs all programmed so at different times of day the color temperature is changed, so pressing button 1 first just turns the light on. If I don't want the color temperature that is set, then I can rotate through 5 color temperatures by pressing button 1 repeatedly.
I implemented dim/brighten with single presses in increments of 20...would love to see somebody do the dim/brighten with held/released!
Any ideas for button 3? I was thinking maybe to toggle all lights on/off. Nothing implemented yet.
This is a parent/child app, so install both pieces of app code, then install the parent app and set the children from there. There will be one child per pico remote.
Please feel free to take and modify as you wish!
 *  Pico color temp bulb controller
definition(name: "Pico Color Temp Bulb Controller",
           namespace: "hubitat",
           author: "dagrider",
           description: "Cycle through bulb color temps with button 1, off with button 5, dim with buttons 2 and 4 (parent)",
           category: "Green Living",
           singleInstance: true,
           iconUrl: "https://s3.amazonaws.com/smartapp-icons/Meta/temp_thermo-switch.png",
           iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Meta/temp_thermo-switch@2x.png")
preferences {
    page(name: "mainPage", title: "Pico Color Temp Bulb Controller", install: true, uninstall: true, submitOnChange: true) {
        section {
            app(name: "picoInstance", appName: "Pico Color Temp Bulb Controller Instance", namespace: "hubitat", title: "Create Pico Controller", multiple: true)
def installed() {
    log.debug "Installed with settings: ${settings}"
    initialize()
def updated() {
    log.debug "Updated with settings: ${settings}"
    unsubscribe()
    initialize()
def initialize() {
    log.debug "initialize"
    log.debug "there are ${childApps.size()} child smartapps"
    childApps.each {child ->
        log.debug "child app: ${child.label}"
 *  Pico color temp bulb controller instance
 *  Button 1 presses:
 *  1: turn bulb(s) on (can have the bulb programmed to set color temp depending on time of day, when it is turned on)
 *  2: set bulb(s) to Nightlight
 *  3: set bulb(s) to Relax
 *  4: set bulb(s) to Read
 *  5: set bulb(s) to Concentrate
 *  6: set bulb(s) to Energize
 *  7: back to Nightlight, etc
definition(name: "Pico Color Temp Bulb Controller Instance",
           author: "dagrider",
           description: "Cycle through bulb color temps with button 1, off with button 5, dim with buttons 2 and 4 (instance)",
           parent: "hubitat:Pico Color Temp Bulb Controller",
preferences {
    section {
        input "thePico", "capability.pushableButton", title: "Choose Pico Remote"
        input "theBulb", "capability.colorTemperature", title: "Choose bulb/group to control"
def installed() {
    initialize()
def updated() {
    unsubscribe()
    initialize()
def initialize() {
    subscribe(thePico, "pushed", pushedHandler)
    subscribe(theBulb, "switch", switchHandler)
    state.pressNum = 0
def pushedHandler(evt) {
    switch(evt.value) {
        case "1":
            log.debug "button 1 pushed"
            if (state.pressNum == 0) {
                    log.debug "pressNum is 0, On"
                    bulbOn()
                    sendEvent(name: "on", value: "pressNum: $state.pressNum", descriptionText: "Turn bulb on")
                    state.pressNum = 1
            } else if (state.pressNum == 1) {
                    log.debug "pressNum is 1, Nightlight"
                    theBulb.setLevel(1)
                    theBulb.setColorTemperature(2237)
                    sendEvent(name: "on", value: "pressNum: $state.pressNum", descriptionText: "Set bulb to Nightlight")
                    state.pressNum = 2
            } else if (state.pressNum == 2) {
                    log.debug "pressNum is 2, Relax"
                    theBulb.setLevel(57)
                    sendEvent(name: "on", value: "pressNum: $state.pressNum", descriptionText: "Set bulb to Relax")
                    state.pressNum = 3
            } else if (state.pressNum == 3) {
                    log.debug "pressNum is 3, Read"
                    theBulb.setColorTemperature(2890)
                    theBulb.setLevel(100)
                    sendEvent(name: "on", value: "pressNum: $state.pressNum", descriptionText: "Set bulb to Read")
                    state.pressNum = 4
            } else if (state.pressNum == 4) {
                    log.debug "pressNum is 4, Concentrate"
                    theBulb.setColorTemperature(4292)
                    sendEvent(name: "on", value: "pressNum: $state.pressNum", descriptionText: "Set bulb to Concentrate")
                    state.pressNum = 5
            } else if (state.pressNum == 5) {
                    log.debug "pressNum is 5, Energize"
                    theBulb.setColorTemperature(6536)
                    sendEvent(name: "on", value: "pressNum: $state.pressNum", descriptionText: "Set bulb to Energize")
                    state.pressNum = 1
            break;
        case "2":
            log.debug "button 2 pushed"
            if (theBulb.currentValue("switch") == "off") {
                bulbOn()
                sendEvent(name: "brighten", value: "", descriptionText: "Brighten bulb to on")
            } else {
                def lvl = getLevel(1)
                log.debug "brighten to level $lvl"
                theBulb.setLevel(lvl)
                sendEvent(name: "brighten", value: "level: $lvl", descriptionText: "Brighten bulb to $lvl")
            break;
        case "3":
            // todo: center button
            break;
        case "4":
            log.debug "button 4 pushed"
            if (theBulb.currentValue("switch") != "off") {
                def lvl = getLevel(0)
                log.debug "dim to level $lvl"
                if (lvl == 0) {
                    bulbOff()
                    sendEvent(name: "dim", value: "", descriptionText: "Dim bulb to off")
                } else {
                    sendEvent(name: "dim", value: "level: $lvl", descriptionText: "Dim bulb to $lvl")
            break;
        case "5":
            log.debug "button 5 pushed"
            bulbOff()
            sendEvent(name: "off", value: "pressNum: $state.pressNum", descriptionText: "Turn bulb off")
            break;
        default:
            return
private bulbOn() {
    theBulb.on()
    theBulb.refresh()
private bulbOff() {
    theBulb.off()
    theBulb.refresh()
    state.pressNum = 0
def switchHandler(evt) {
    switch(evt.value) {
        case "on":
            state.pressNum = 1
            break
        case "off":
            state.pressNum = 0
            break
private int getLevel(typ) {
    def lvl = theBulb.currentValue("level").toInteger()
    log.debug "current level: $lvl"
    switch (lvl) {
        case 0..10:
            lvl = 0
            break
        case 11..30:
            lvl = 20
            break
        case 31..50:
            lvl = 40
            break
        case 51..70:
            lvl = 60
            break
        case 71..90:
            lvl = 80
            break
        default:
            lvl = 100
            break
    log.debug "adjusted level: $lvl"
    if (typ == 1) lvl = lvl + 20
    else lvl = lvl - 20
    if (lvl > 100) lvl = 100
    else if (lvl <= 0) lvl = 0
    log.debug "new level: $lvl"
    return lvl
