We've had some pretty sever storms lately, knocking grid mains power out.
My APC UPS worked flawlessly, shutting the C-8 hub & NAS down when it's battery got to the point it couldn't maintain power. Logs show mains went down at 10:30pm, and the UPS lasted until 3:40am, all while we were asleep.
When I woke up, I didn't know the hub was down (didn't have my morning coffee yet), even tho the the rest of the house was dark (DUH). No stand-by whole house generator to pick up the slack.
When I did fire up a generator, I then found out the hub & NAS were powered down nicely.
I had to wait for the UPS to recharge enough to restart the systems.
I'm looking for other, more obvious, indicators, that things went as planned.
What does everyone else do for long term grid outages & indicators? Maybe a physical flag that pops up out of a tube, etc.
I use a CyberPower SL700U for the hub and my router. No auto shutdown setup. That UPS should keep the hub and router going for quite a while. I live in northern Mexico and while our power does go out more often that it did when I lived in Phoenix when it does it's rarely for more than a few minutes. The max was about 4 hours during a huge wind storm a few years back on New Years Eve that knocked down some big power lines. I figured it would be out for days but the crew got it bypassed very quickly.
I have a bunch of different UPSes. I tried doing a couple USB battery packs (charging THOSE with PoE) but could not find one that seemed to have a good switchover when losing power. So now, all the network and hubs are on UPS backup.
Our power was out for 12 1/2 hours from the storms we had the other day though (maybe same ones that caught you) so it certainly outlasted the backups. We lost it again this morning (likely while the power company is doing repairs or other tree issues) but everything was fine.
The tree companies are SUPER busy with all the damage in the area, it has been constant chainsaws and chippers...
I use ecoflow, with the solar panels it kinda gives me a redundant power setup. No sun, No power i can keep critical devices powered for ~24hrs. As long as i can collect 3-4kw of solar power daily, i can power critical loads throughout the 6 months of a TX summer.
In the increasingly less rare case of a power outage during not summer, local notifications are sent, and my critical loads shut themselves down safely before my batteries give up.
I got the Costco deal of the Ecoflow River and External battery a long time ago. That runs to a UPS and then the UPS to my network equipment. The reason I have the UPS in the loop the cutover time of the River was too long (heck they didn't call it UPS mode either) so the UPS runs for like 5 seconds until the Ecoflow switches over to battery vs. passthrough voltage.
Newer Ecoflow hardware has much faster switch over but until this solution dies I am sticking with it.
I have a Konnected battery to my Alarm boards, buzzer and siren. I do not have any other UPS. Reportedly, the Konnected battery will last 8-14 hours without charge. We do not have power outages much here. And when we do, the power is restored pretty quickly. I guess I am saying that I don't think that I need a UPS. Yes, my hub does not do a shutdown, so the possibility of corruption is there. That's what daily backups are for.
Quite a few of us use the Ring Alarm Range Extender plug that includes a battery, so it's reported power status (on mains or battery) can be used in an automation to send yourself an alert when power goes down (assuming your hub is on a UPS and stays up long enough to communicate).
The APC BX1500M has been pretty rock solid for indicating the output power source, be it Mains or Battery.
The UPS data port is connected to my Synology NAS. The Synology NAS Power option tab, reports the power status to the C-8 Hub.
As a backup, I am also running HA to keep tabs on the C-8. The C-8 is keeping tabs on the NAS/HA. Maybe this is overkill, but it's a closed loop monitoring system.
I have a Zooz ZAC38 to monitor power on a pump branch circuit. It has a battery in it so will transmit a power loss state change inbound, then I have a rule triggered by the device switching from mains powered to battery powered.
You could use this to detect loss of mains power and take actions accordingly.
I'm using a refurbished traffic light UPS (pure sign wave) with four LiFePo4 100Ah batteries giving me 5120 watt hours of energy.
This unit is for my refrigerator and lasts a little over 24 hours, so I plugged my C-8 pro hub into to that along with the fridge. I have meds that require refrigeration.
I do need to interface the UPS with the C8 but haven't gotten around to it and this post reminds me
It's setup to close a relay contact at a specified battery level so I just need to figure out how to get an input to the hub, with probably a Zen58 input or contact sensor.
Now getting that input to the hub to force a managed shutdown might be a little tougher to figure out for me?
Detecting the loss is already handled, w/ the UPS reporting the Mains/Battery power source. After everything is shutdown, the question is what's next. I've already got emails & log data available, but that takes a computer to interrogate everything.
I'm wondering how I can let my wife know not to expect any automations BEFORE she looks for them. Hmmmmmmm.......This rabbit hole continues......
For the hub, it's much more efficient to use a DC UPS, Like a PiPower dual battery UPS, runs my hub for 3 days. Or use a talentcell Modem UPS, also DC. With the PiPower I can swap out the 21700 cells when they die, with the Talentcell you have to trash the whole unit or employ soldering/spot welding cells together to rebuild the pack.
Cyberpower up on the home network shelf. Raspberry PI 4 running NUT monitors the UPS. PI sends Hubitat a shut down command after 30 minutes on the UPS. If I am home, I rig up a propane powered standby generator through a Reliant 50Amp 10 circuit transfer switch before the 30 minutes passes.
Sigenergy 40KW house battery with backup protection (no down time) and 25 KW DC charger capable of V2H along with 60KW tesla and 100KW Zeekr cars as additional battery if needed
the thing with many of these solutions vs mine with smart ups and network card... No monitoring so no shutdown hub cleanly if power is out for extended times and about to run out...
