So as the title suggests I am trying to set up a well pump relay to ■■■■ off the well pump when a leak is detected but I am having a few issues.
I have the relays set up to shut off when a leak is detected and this works perfect. The shutoff valve closes siren goes off and some lights in the house turn on. All is good until you clear the alert in HSM. As soon as you do this the siren stops and relay turns back on. If the leak is between the pump and the valve that is no good. So is there a way to make this not turn back on? I am confused since the lights that were turned on do not turn off when alert is cleared.
I wanted to set up a notification if a leak is detected. I copied a known good message from my alarm settings and nothing happens. I tried checking for updates for hub and app they are good. Force closed the app and I can't see what notifications it has...it just churns. Tried rebooting phone and hub no change. So I tested alerts that used to work for house alarm and a motion sensor, neither work. But I know this was working around Easter when my sister accidentally set off the alarm. So between then and now I have nothing. The alarm seems to be functioning as programmed but no alerts if tripped. Any ideas?
Finally, for either a intrusion alarm or a water leak I have it set to turn on a Sengled led strip in my son's room. If intrusion it lights up red and blue if a water leak. This works but works different even though they are set up the same. For water leak, if I clear the alarm in HSM only this light goes out, the others in the house stay on. For intrusion when you clear the alarm it stays illuminated as do the other lights. I can't figure out why this would be the case. Thoughts?
