I have a wierd issue with adding new zigbee WeLink/CMARS outlet. When it gets added It's added as “Device”. I change the driver to generic zigbee outlet and it will turn the device on and off. However, a mess happens after that. The outlet turns it self off automatically in 2-20 seconds once it’s turned on. If i physically hit the button or or do it via Hubitat it will turn itself off. I thought it was the driver so I found a customer driver and the same issue happen. It will not stay on, and Hubitat thinks it’s on when it’s off.
I have a C7 connected via mesh with a different channel for zigbee. When I add it to the C7 it works fine.
My thought is that something with the C8 radio is causing it to not work right. Is a network ping forcing it to turn off?
BTW it’s in the same location…the two hubs are right next to each other and the switch is about 5 feet away from the hubs.
Edit…I have roughly 6-8 of these already on the C8 and they work great. They were migrated from the C7 and not newly added to the C8.
