Weird Happenings with Zigbee devices
I have 7 zigbee devices. I get some weird acting of some of them.
  1. Wemo bulb. When I turn it on it immediately returns the status of it being on. When I turn it off the status never changes to off unless I do a refresh. Bulb does go off, but status doesn't change.
  2. Iris V2 keypad. Takes about 10 seconds for a command from the keypad to make it to Hubitat. And If I send a command to the keypad same issue.
  3. Sengled bulb. Comes on ramdomly for no apparent reason.
I have checked logs for these things and don't see any reasons or errors or abnormalies.
Same issue with OSRAM/Lightify bulbs using the Generic Zigbee Bulb driver has been reported. I'm thinking it's a driver issue.
I have 8 Osram/Lightify RGBW A19 - none of mine have this issue. If it is driver related, it might be specific to particular firmware revisions on the Osram bulb.
The one I tested was not a RGBW bulb.
This behavior seems to happen with the non-tunable white Osram bulb. There was some discussion a while ago:
Wemo Zigbee bulbs aren't on our supported devices list, so not having tested any of our drivers with these I can't say what the problem is here.
This smells of routing/mesh issues, these keypads can take up to 3 seconds to respond to commands from the hub, but commands generated by the keypad should hit the driver in well under a second.
Don't have an answer to this one, personally I would remove/factory reset then include this bulb again. At the lease this will remove any potential zigbee groups and or application bindings that may be inadvertently attached to the bulb.
