Weird Alexa Thing
This wasn't happening orginally...so my "assumption" is they changed something on the Alexa end?
I have a virtual blind "bedroom blinds" that I use to trigger a group of blinds to open/close.
Now when I tell Alexa to open or close them...she comes back and says it didn't respond and to make sure it's turned on and has power?
Anyway to stop that?
thx
Did you change anything? Specifically, what platform version are you running? :slight_smile:
That being said, I'm not noticing this problem with real blinds. I do have "blinds" in the name for all, in reference to another post I see you made.
To directly answer your question, there is an option you can enable on a per-device basis in the Alexa integration on your hub that will force Alexa to pretend that everything is OK even if it doesn't hear back from the device in whatever time (enable "Show options to respond immediately instead of waiting for device," then you'll see it), which should prevent this message, but I'd still be curious what's really going on here.
Sure...I'm pretty good at keeping the hub and apps up to date.
This may actually be a bigger problem since I have a virtual switch call "tablets" which I use to trigger a rule to change them and turn screensavers on one of them etc at night.
Alexa said the same thing when I tried to trigger it this morning.
Then Alexa said she would discover my tablets. I think that list of secret words like "screen" you can't use with Alexa is growing.
PS - When doing network support that was always my first q too...what did you change.:upside_down_face:
And they always said nothing :slightly_smiling_face:
And yes disabling that may be what I have to do...but I rather find a solution/cause and understand it.
