webCoRE Won't Match Identical Text Strings?
I'm using a simple restriction that should match the name of the device to a text string, but webCoRE has decided the strings don't match.
I can work around it if I have to, but why is a simple comparison failing? Is there some formatting to the text string I can't see?
Can you post a simple example so can verify what is going on?
I changed the name of the device to Living Room TV and it started working. If it happens again I will post an example.
