Anyone else having this issue. When I updated Webcore I keep getting this WARNING: Results may be unreliable because the parent app’s version(v0.3.111.20210130_HE) is newer than the child app’s version(v0.3.110.20200210_HE). Please consider updating both apps to the same version. When I under Apps code it has the current version. What am I missing?
I used Hubitat Package Manager to update it. How do I roll back an update? Any help appreciated.
If you installed using HPM, try doing a repair, if you didn’t try pulling down a new version of the Piston child app.
Yes I’ve tried that and I still get the error message
Will try to find new version haven't seen it yet.
So I would
do an HPM "repair" on webcore (not an update, repair)
- if you used HPM to install
If you installed the files by hand, install the webcore, and piston files with latest from the git repo
Go into webcore (HE console -> Apps -> webcore) and hit done
reboot your hub (be nice HE console -> settings -> reboot hub)
Let it settle
- see if things are working)
Ok I tried the following with no success. Thinking about starting from scratch and doing an uninstall/reinstall. The bad part is I can’t even back up the pistons getting an error message
is there a way to roll it back?
- Rebooted HE hub
- Did an HPM repair(already had done so yesterday)
- Tried to edit them as ipaterson suggest( not sure if I did that correctly though)
- Hit done
did you try the new version that was released within the last 24 hours?
- Last update February 2, 2021 for Hubitat
static String version(){ return "v0.3.112.20210202" }
static String HEversion(){ return "v0.3.112.20210202_HE" }
reload the page in your browser
there wasn't a reload button on the dashboard hit Ctrl+F5 and it refreshed and after all that still have the message. going to try all the other steps again I did before
now getting this message
I reloaded everything and still get his:
A newer UI version (v0.3.112.20210202) is available, please hard reload this web page to get the newest version.
I cleared the cache and I'm back to SmartThings, Oh the horror
A newer SmartApp version (v0.3.113.20210203) is available.
This is an optional update; consider updating the webCoRE SmartApps in the SmartThings IDE.
Okay not sure what the deal is with this message but I cleared the logs and reset my logging level because it had reset to none and the message is gone Have to do this for each piston but the message does not seem to be coming back crossing my fingers
are you able to make backups of your pistons now?
Nope! Message gone but new problem
last thing I can think to try is clean up and rebuild data cache in webcore > settings
Couple of things
check that you have the latest webcore sources (for webcore main and piston)
- HPM repair, or manually load those two files (and save)
Nicely reboot your hub (HE console -> settings -> reboot hub)
After the hub is back up, clear your browser caches, and exit the browser
Start your browser & Connect to dashboard or staging on webcore
Once the dashboard is up, load a small piston first. Get out of it, and load whatever piston you want
If you want to clear on the logs on your pistons
- you can do them all at once if you enable debug for the webcore main process
- then in HE console -> apps -> webcore main -> settings - "clear logs, stats, traces"
- give it 30 seconds to finish
