I don't use WebCore!
Does anyone know why I am suddenly getting these in my system events:
did you?
No way!
...and this is happening to others as well!
What! Even on ST? Is HE using the same IP address?
On the other thread you posted on someone is asking you about Homebridge.
Yes, I use Homebridge V2 from @tonesto7
Is that using WebCore? (under the covers?)
Another thread discussing same issue
MakerAPI is a built in app.
It shouldn't be using WebCore - except by mistake!
@gopher.ny:
I hope that I asking the right person.
Does MakerAPI use WebCore?
It doesn't. There's no mention of Webcore in any of our code - I just ran a search to be 100% sure.
Thank you!
I'm seeing the WebCore system events as well. Brand new C-7, clean install, less than a week old. Only apps are Homebridge v2 and Hubitat Package Manager.
Message is from the Homebridge app when it is checking to see if you have any webCore data that needs to be tranferred to Homebridge. (about line 693)
Is it possible you have a custom driver installed, which supports webCoRE?
I think that @vettester has the correct idea.
Ah ok. That makes sense now. I was confused since I don't use WebCore. Thnx!
