I just set up Webcore this week (I am coming from ST) and got a new driver working for my Homeseer HS-WD200 switches.
If I click the "push" button in the device tab the code is triggering a webcore piston with a pushed event. I have a debug log entry in that function to confirm it fires.
But if I tap the device and trigger the same function (that generates the pushed event), webcore doesn't run.
Did I set up webcore incorrectly?
Here is the event code from the device handler (I also overrode "$buttonType" with "digital" each time, and it didn't change how things operate)
Sometimes when moving piston from ST you need to recreate the if statement that includes a button.
It would be easier to see if you post your piston in logs to see what is happening, but without that data my first suggestion is to recreate the if / trigger statement for the button you are using incase the import from ST included different button values
Agreed. It seems Hubitat handles buttons differently than ST does. I do not have any Homeseer buttons, but have multiple ST buttons and was able to get those all working inside Hubitat.
I would recommend starting with a fresh Webcore piston and playing around with it until you can see the button responding correctly. My ST button piston logic looks like this.
