I noticed that when the logging level is set to full, while debugging a piston for example, the log size is quite small and rarely capture the initial trigger for complex piston. I used to be able to capture relatively long log in ST, but it seems that the log size is extremely limited in HE. Is there any way to increase log size for Webcore pistons? Thanks!
go to
HE console -> apps -> select your piston
change Max number of history logs (max is 300)
and save/done your way out
Thank you so much! For whatever reason I never looked there.
