I have a local server running on docker on my synology. I registered the browser etc. I create a new blank piston but when I click to add statement, I get nothing.
Thoughts?
ensure you are using the proper repo for the webCoRE IDE (web) files.
Ensure you logout in your browser, clear caches.
Note 2 in the main webCoRE thread has info on this.
Additional details on how things work:
webCoRE Operations
Your pistons execute locally and if the webCoRE servers/internet are down, pistons keep working (unless the piston is using one of the below mentioned webCoRE server functions).
It is possible to run the webCoRE [dashboard] server locally (see below)
Your piston is stored in HE hub (inside the piston child application). When in the webCoRE dashboard and you want to edit a piston, the webCoRE dashboard requests the code from HE, and …
system
Closed
March 7, 2026, 10:11pm
3
This topic was automatically closed 1095 days after the last reply. New replies are no longer allowed.
