Webcore - I have been quite impressed with Gemini and streamlining/troubleshooting my code
I have been running my long-working pistons through Gemini and am getting some really good results.
Would be interesting to see what it corrects.
I have quite a few but not as many as you. :wink:
I find WebCore has some programming quirks; some are internal and have to be worked around.
As an old programmer it would like to see what it does with my subroutines and args. I think I'm fairly precise but when C was invented my eye glossed over when the 'young folk" got ahold of it and made a whole routine in one line of gobblydygook special chars. :wink:
Example : I use webcore heavily for my home audio system and Kodi on a RPi. So I am doing lots of HTTP calls for things. I never really took the time to learn much about the syntax for the JSON that Kodi uses. Basically I pulled together work from other Kodi users. But Gemini pointed out some errors in my sequence of HTTP commands and some syntax issues. OLD : clear playlist, turn shuffle on, load new playlist, play. NEW : clear playlist, load new playlist, play, shuffle. And some housekeeping syntax to go with those changes. The changes recommended by Gemini seem to be working better than the original.
I see.
I just left Kodi/UMS for Moonfin/Jellyfin so I can't be tempted to go down another rabbit hole. :slight_smile:
