Ok! I just found, its linked with latest reply @nh.schottfam , I just used if condition at the place of events. The trigger within the conditions allows for daily at time and can be merged with or switch changes… so I just create a variable (must be time variable) and set it first time to now + 5 minutes .
After that I just need to set the time variable to now + 5 minutes again…
So, each 5 minutes it run and if a change occurs with the switch… (ideally the switch should not set the time…)
Thanks again for all those ideas!
