Once this piston fires, does the trigger reset? Will this piston fire again in 15 minutes?
After a simple test, it appears that the trigger does not reset.
Yes this resets and compares to the previous event but sometimes I get confused on all the options; some only trigger once. Stay, remains, rises, drops Oy vey
I use this and it constantly monitors.
Another example that seems to reset.
I can pause and resume the original piston to reset the trigger, but that requires a separate piston and the rabbit hole ensues.....
I can shorten my EVL piston and test again.
Ok, I shortened my ping and test time and did 3 cycles of fail, and test the Stays condition and it came back testing the Stays and worked every time.
