Hi all!
I created, using an AI (chatGPT codex), a CLI (command line) based plugin to access Webcore via HE. This way you can prompt it to verify your pistons and suggest fixes. Not only that but it is able to modify the pistons and even check that Webcore implemented the changes.
Always backup your pistons prior to having AI tinker with them. Hope this helps those challenged in coding.
Here's the github link to the files and readme file: Webcore CLI plugin
