Here is the Set Variable command:
I am getting the track data from my Amazon Echo. Is there any way to change the font size here?
Font size is set by the UI, could possibly do a + to increase the browser display size though.
The text is displayed on a dashboard. I was hoping that there was a webcore text function or similar to increase the font size when assigning the text.
If it's the classic dashboard you may be able to play with the CSS for the element and change the text size there.
Nope, using HD+ dashboard. I think there might be a formatting option in that app.
You used to be able to embed a <span style="size:15px">variable value</span> when you set the variable but I believe that has been removed.
Yes, I have been working with that for the last hour. No dice.
You can make the hub variable a connector, and instead of setting it using the @@ variable in Webcore, share the connector device with Webcore and set the attribute like with any other attribute in a device. That should let you use <span style="size:15px">variable value</span> to set the string attribute there.
The hub variable itself will probably still strip out the style, but I assume the attribute in the connector device will keep the formatting. In that case, you then use the variable connector device value on the dashboard, instead of the hub variable directly.
Seems that should work, but I have not tested it.
I will give it a shot. Thanks.
