Webcore Bug List
Is there an ongoing list of Webcore bugs that will be fixed in the next release? Here's one. As I moved many pistons from ST to HE, I found a few more but this is the only one I remember now.
  1. pasting a condition into an Elseif statement does not work. I find that when this happens, I need to close editing that piston, and restarting the editing session with redoing the edits I made up to that point. Otherwise, it seems to cause other problems with the edit. The workaround is to not do a paste but to manually replicate the statement. To replicate this bug, copy a condition from an If statement, then attempt to do a paste into Elseif.
Also what is the plan for the next Webcore release?
And, thanks for your hard work in getting Webcore working on Hubitat. I did not realize how smooth and fast pistons work on this platform vs ST.
While I do not currently use webCoRE, I believe most of the webCoRE developers probably answer these types of questions over on the webCoRE Community Forum. Lots of good info about webCoRE over there.
Glad to hear you're enjoying your Hubitat Hub!
@ipaterson can comment on the web code changes.
