This is my second hub and I believe I followed the directions correctly again. I named it and put in the zip code but the name seems to come back as "My New Hub" Any suggestions on how to reset it so I can try again or is there some other way to get my new C7 working?
I turned it off for a couple hours, then on the iOS app I cleared the debug log and tried to add it again and this time it worked. I'm trying to upgrade the firmware but I keep getting 404 not founds and failures loading new firmware. I have a ticket in with Hubitat.
Yeah I think this is going to be a support only fix. If you’re getting that Debian error page when going to the hub’s IP, something is definitely not loaded and working on the hub.
Problem solved. I had a somewhat obscure IP address conflict that took a bit of troubleshooting to resolve. The HE is working perfectly and my issue was self-inflicted.
