Web Interface doesn't run
Hello, I have hubitat time ago, today web interface didn't run, I run ip:8081 after reboot hub doesn't run web interface and doesn't work anything.
I have restore previous version and not work.
Revoir on safe mode don't run web interface.
Led on hub is blue.
What can I do?
What version hub do you have?
I just checked the hub, it look like it got full reset. That usually works.
There's one (manual) thing to try before a full reset under this circumstance.
curl -X POST http://hubs.ip.address.here:8081/api/getLatest
...followed by a version switch and a reboot. The endpoint above can download the latest runtime. There will be an update to the diagnostics tool to expose this endpoint through UI.
Full reset work... Thanks. Hub without devices and configuration :(.
Thanks.
I have a c5
