Weather attributes
These are the current attributes presented by the Weewx & External driver (Currently using WU)
These should all be 'switchable' via my Weather Switch app
I am working on Max/Min temperature recorded today and Max/Min wind recorded today.
Once these are added to the driver I'll make them switchable via WS
You're a good soul. Just can't resist eh? :wink:
This weewx driver uses either WU or Apixu (selectable)
I'll release it soon but will probably wait until I have completed the min/max stuff
Then I'll be adding them to WS
I'll continue to use my WU api until they stop me as WU gives me a bit more than Apixu
Andy
This is currently what Weather Switch can act upon:
Andy
Andy, I'm in an old house and for the most part I've solved basement flooding issues, but if it comes down really fast, I'll get some water in the basement. Will you expose "rain_rate" to Weather Switch please, so I may setup a notification to check the basement when I return home if there's been a fast falling rain?
@SmartHomePrimer
I'll need to write another handler method for this, but, yes I can do that for you.
I should be able to look at this in the morning
Andy
Thanks Andy. No rush. I'm able to get email notificaitons at the moment from the Ambientweather.net website, but I'm just looking to the future when I'm using Weewx and Apixu, where I won't be able to upload to Ambientweather.net anymore.
@SmartHomePrimer
Updated Weather Switch 'child' to version 2.4.0 on github
Try that :slight_smile:
Andy
OOPs.. just discovered a typo... hang on a bit :slight_smile:
LOL. Go to sleep! It can wait. :grinning:
LOL
Done already!
V2.4.1 uploaded :slight_smile:
This version also includes much better remote version checking code for any future updates
Andy
Thanks Andy. Expecting about 5 mm of rain tomorrow. I set the rate threshold to below 1 mm for the test. I will let you know if there are any issues.
[Edit] Set up another weather switch with threshold above 1 mm as well, just to cover all the bases. :grin:
