I've tried some of the online water flow thru pipe calculators, water pressure loss calculators, etc., but the results don't make sense (or more likely I don't understand what they are trying to tell me).
My water well puts out about 20 GPM at 50 PSI at the tank. I want to run a water line from the well tank to the front of my property (about 1500' total length). The land is flat. I plan to use 1" PVC buried.
What kind of volume/pressure can I expect at the far end? I'm hoping for at least 5 GPM at 30 PSI.
