I just bought a SONOFF SNZB-05P Zigbee Water Leak Sensor thinking it would be just the thing to cover more than just a single spot. But I'm having hesitations.
When I tested it by touching the cable to water, it did raise a wet event. The problem is it stayed there for a long time, then went wet/dry for a while, despite efforts to dry it. I also note that reviews say it is prone to false positives since humidity can trigger it as well.
My particular application is to have the sensor cable inside a wall surrounding a shower stall so I can detect leaks from the valve or elbow joint (or the shower pan itself even). But I'm wondering if a false wet will have me ripping out tile or drywall to find out what's going on unnecessarily.
I have also found this type of sensor is sensitive to humidity and they do take a while to reset. I would expect false alarms if the bathroom air is getting into the wall. If it's sealed up well, it might not be an issue. In my case(s) the sensors were in a kitchen and the false alerts occurred when the A/C was off and the windows were open.
Yeah, I did that connected to the two screw terminals on a Third Reality water leak sensor. Maybe I'll do something like that with multiple points where the leads are bare and close together.
Meanwhile, the Sonoff sensor dried out after a little over an hour. I can certainly see the value in continuous sensors, but not sure this use case is suited for it.
I am using these sensor cables connected to the adc input of esp32 with 10K pull up resistor. This is a leak detector portion of a complex diy controller. My experience with these cables is very good but the device is diy.
I'm using the cables under my kitchen sink, around my water heater, in my sealed & conditioned crawl, and under the wall mounted cantilevered vanity in the guest bath and have never had an issue with false positives. They are very sensitive. Mine went off when a kid shoved a soaking wet towel under the guest bath vanity instead of hanging it up. My water totally shuts when my sensors detect water. Made an impression on the kid - this particular kid now hangs up the towel on visits. Granted, kid was under 10 when then this incident occurred.
I have never tried the sensing cables with the nylon fabric on them, to tell the truth, I had never seen those before seing this post. The cables I have are custom cables I make my self that I buy in 10 meter length on AliExpress and then make them the length I need, they are just a a fluoropolymer rod with grooves and 2 sensing wires incrusted in the rod. Most of the time when testing they will not stay active when no more water contact but I did see a couple of times where a water drop would keep the sensor active but only a few times. Here is a picture of the type of cable I have used...
They also have a type that has 4 wires wrapped around in four different grooves, 2 are the sensor wires and the other 2 are for transferring signal/power to another module further down the line (maybe a repeater for longer cables?)
For a shower-wall run, covering more area with a cable is tempting, but humidity false wet is a real risk in that spot. If you go fabric, name the sensor for the exact place you'd inspect, and treat wet as go look now, not rip tile yet. A later dry report also isn't proof the leak is gone. Probe-style leads sometimes behave cleaner than fabric in damp bathrooms, but whatever you pick, the alert pattern matters as much as the cable.
I wrote the response pattern up here (name the sensor, alert hard, clear only after a person checks):
I like my plastic ones. I do not like my yolink ones because they are fabric and take forever to dry to reset. I bought the plastic type in a spool and use it with most any water sensor.
Something like this? This does look like it would be far superior to the fabric ones. Although it says it isn't compatible with any other sensor, I can't imagine it is anything other than a normally open pair of wires and the two bare ends could be connected to any leak or contact sensor with attachment points.
That's exactly the type of cable I mentioned above that I use and very happy with it. I first used it on a Sinope water heater switch that has a built in water leak sensor 1/8" jack. Sinope was asking part of an arm for the cable, so I made one for a fraction of the money and it works great, then I started hacking my other leak sensors to be able to use this kind of cable.
