Hello, gang. I'm baaaack!
Hubitat C-8 (not the Pro) on the latest firmware
The Situation: I bought some leak detectors (Zooz XS ZSE42). I just added one to my hub. I know it works because its state goes from Dry to Wet in the Current States box, and does it nice and fast.
The Problem: I wrote an experimental Rule Machine rule in order to give it a test. The rule is below. To my techie mind, this could not be any more straightforward, yet it does not work. It does not flash. I revised the rule to simply turn on the lamp, and that works.
What have I done wrong?
Bonus Question: I chose a lamp with an LED bulb in it used as a night light and is controlled with a Third Reality smart plug that I know for a fact works flawlessly. I'd like to get a bit fancier than that. I want to take a Third Reality RGBW bulb already in my system, and have it flash blue.
