Water event information
I had a moisture event today, leak smart shut off the water and pushover let me know what happened... BUT... i needed to pull out the laptop to figure out which sensor was calling out the wet. How do I get a notification to include which sensor tripped?
Depending on the App your using you can often use %device% in the Pushover Message.
%time% and %date% are other attributes that can be used and are usually identified in the App.
