Warranty request
I just purchased a c8 pro thread special edition and the z wave radio is apparently dead. I've done all the resets, rolled back to the previous version after it updated on first boot etc.
I submitted a warranty request but got no email or any confirmation the ticket was opened. I've done all of the troubleshooting so I'm just wanting to verify my request was received.
Probably won't help, but try shutting down, when hub LED turns red pull power, wait 30s, then restore power. Pulling power restarts the radios.
Yes thank you for attempting, but I did that a couple times, as well as did full reset, did soft zwave reset, rolled back the update. Factory reset the zwave devices powering the hub back up. Been going at it for hours.
Tagging @bobbyD from the Hubitat Team.
@bishop.scottm Please PM me your hub ID.. If I can look at the logs it might be something simple that can be fixed.
Yes, it has been received, and our engineers are reviewing your case. You should receive an update by the end of the day.
ZWave-JS had a partial install that allowed it to pass validation but not start up properly.. Force re-installed ZWave-JS using an endpoint.. And all is working now.
