Thanks guys. Yeah, I had intended to go all RA2, but after a test have found that my old Insteon dimmers work really well with the dimmable LED ceiling lights that I put into my home for sale. I've fallen for my Insteon dimmers again! $60 CAD for quality dimmers that have programmable ramp rates and dim level memory.
I got around this by using the ELV dimmers (which include favorite setting), then setting the favorite level to the minimum level. Then set up a level by mode rule, or auto dimmer (in our public repo now), then instruct users to turn on via favorite button...
its a software application that's not included in our hub distribution but is available to add manually if desired.
It's located in out public gethub repo along with other example code.
Make sure that you buy a new one or if it is used confirm that the HomeKit integration has been deleted on their side. You many never be able get HomeKit working if it is not. Factory reset does not affect this.
Thanks. I found the right seller on Amazon.com to ship me a new SmartBridge Pro. No good enough deals on the RA2 Select Main Repeater right now.
The Insteon integration is for the hub. You will need an RPi or spare computer to run the node.js apps that control and listen to the Insteon hub. I run mine on an old Mac laptop. It is the most stable of all my Smart Home devices.
Something to keep in mind. I am trying to switch over my customers to Caseta and most agree. I have Insteon installations as old as 2008 (with a dual band upgrade along the way). I used the ISY with the exception of one home, which uses the hub.
