Thanks bertabcd1234: for clarifying the non existence of connectors, and, I kinda thought it would be the case that local variables couldn't be used as triggers.
Also, I was using the term global variables and Hub variables interchangeably. I didn't know about global variables in previous iterations. Sorry.
Just to chat, (all of this I can do myself, I just thought it'd be an interesting topic for people with nothing else to do, LOL)
I want to control the temperature in my bedroom by a profile:
Specifically, at
07:30 set to 70 degrees,
10:00 set to 55, and
23:00 set to 66.
I can (and am now) using hub variables for the times. Some examples are
GV_time_master_bed_awake,
GV_time_master_bed away, and
GV_time_master_bed_sleep.
This is kinda the wrong place for these as I have 5 rooms that go on and off at different times, like the theater room, guest bedroom, office, and living room.
That's a lot of variables I'd rather store in the rules themselves vs having them in the Hub Variables list.
I am looking into using files in File Manager, I see there is a device that can read files into variables, that opens up a plethora of possibilities.
And to add a level of complication, I want to use mode settings Summer, Winter, and Spring and fall to modify the temperatures and times. I'm still working on how to handle that.
But for now, I have to go Mow the lawn, Finish the window sills, Clean the garage, Change the oil in the truck, Reseed the lawn, Get the patio furniture out of storage, Set up the robomow, setup the irrigation, Trim some trees, Power wash the deck, Replace the banister on the deck, Fix the door to the shed, Insulate the shed, Ready the pool for summer,...
Aggghh. Maybe I'll go watch some TV.
Mark.
