Nice - I like how you use your GE motion switches.
Like @jared.zimmerman the majority of my switches are Lutron Caseta (closets & bathrooms are Zooz). I control my zigbee motion sensors somewhat similarly - such that motion-based lighting is not active in Away mode and dims to a different value in Sleep mode.
I use non-standard Xiaomi motion sensors (which are on a separate Hubitat), and all my automation is done via Node-RED on a separate computer. Even with the delays involved in sending commands over the LAN (or WLAN), I still see motion-based events to occur in 130-180 ms.
Hahaha, yes I do...gives you an idea of how long I've been using those though! And with @ogiewon if it ain't broke... Quite honestly...as much as I thought the old RM was kind of weird...I miss it. It was actually easier to do a lot of things. So I'll be keeping these rules around until the HE team tells me I can't.
@jared.zimmerman I am also working on automating my bathroom light and I use Lutron like I think you do. Long story short using "switch" in my motion rule gave me 180ms response from sensor to light. I change the rule to "set dimmer" and it dropped to 90ms. Not why this made an impact, or how your rule is setup, but wanted to pass on my findings.
Thank you sir! I am using @JasonJoel's driver currently with my motion switch (not dimmer) and may just modify to add these commands to this driver since it has been working quite well for me.
Thank you! The old driver has been working well and I havenāt thought to check. The other night I was blinded walking into my master closet at 2 AM and thought it would be nice to disable the switch during certain timeframes.
