Wait until, stopped working
Updated my C7 hub to version 2.3.9.143 and have noticed my wait until commands have stopped working. All was working fine before that. Anyone else with the same problem or is it just me.
Hi,
Probably not just you. I have the same but I have a C8, I'm on 2.3.9.143 and my "wait until" is no longer working either. The events to switch on work fine, but the device never switches off - there is no event to switch off in device logs. From the dashboard I can switch on/off which clarifies the device is not the issue. I resolved it by having one basic rules app to switch on and another basic rules app to switch off - good thing I have only one device set up to use "wait until". A bit ludicrous to have to do this though.
Kind regards,
Gunnar
Could you please update to 2.3.9.147? There was a bug in .143, .147 should fix it.
Thanks, doing the upgrade! Cheers, G.
Updated and all worked fine, thank you
Yeah, I had a water purification system whose reservoir ran over because it did not shut off after the normal 40 min. run time. Fortunately, I caught it before any damage was done.
I just updated to the new firmware. I hope that fixes it.
