Volt Smart Lighting Control
I'm wondering if anyone has tried to interface to the VOLT SMART lighting system, it uses a network connected hub to communicate with VOLT low voltage LED lamps using bluetooth and zigbee.
The Volt Smart app is simply a rebranded version of Tuya, so the Tuya Integration (Tuya Integration | Hubitat Documentation) might work. The bulbs themselves use Bluetooth mesh and would not be able to be directly connected to Hubitat. I can't tell if the Volt hub is matter compatible, but if it is, that would be another way to connect the outdoor lighting to Hubitat.
