I am looking for a way to have a Thermostat that monitors a temperature device and turns on/off a switch. Ideally I want a dashboard device that I can change the temp I want similar to a light dimmer. I have Cobra Apps / All Average installed. How would I do this? Would there be a means to have temp setback during certain hours? I already have an app that I use but changing the temperature is a PIA. I have to change the settings in the app. Or turn on the switch to get the heat working and then remember to turn it off when I get to the temp I want. Not ideal.
https://community.hubitat.com/uploads/default/optimized/2X/8/8d765c38d0a00e09b6d44d9229d0ee84b2414e0b_1_375x500.png
I use this in rule machine with a virtual thermostat.
‘Temperature Controlled Switch’
Has the ability to use either a fixed temp or temp from a thermostat.
