So with samsung going to a paid API, I am having to change how I control my mini split (currently on HubiThings). I bought and RM4 IR blaster and have it working in Hubitat. I am having to save a bunch of different IR codes.....one for every temp setting in both heat and cool and also vatious other ones. I havn't finished it yet, but I anticipate a sizable ammount of IR codes that will be saved via the device created by Tomw's Broadlink IR/RF remote integration.
I want to create a virtual thermostat in HE and connect it to the Broadlink IR device with all the IR codes. I'm not sure how best to go about this. I could do it via a RuleMachine rule, but that would be quite massive with a ton of different IF statements. I feel like there has to be a good solution via an app in HE, but can't find one that works.
NOTE: My mini split doesnt' send temp up/down signals. Rather I have a separate IR code for 72-cool, 73-cool, 73-heat, etc.
You might be overthinking this. The virtual thermostat can replace the thermostat in the AC entirely, instead of trying to "sync" the temperature between the two.
I only capture three codes:
Cool at the lowest temp setting I will ever use
Fan at any temp setting
Off
When virtual thermostat calls for cool, send the cool code
When virtual thermostat goes to idle, send it fan or off (I use fan for idle to keep circulating)
When virtual thermostat is set to off, send the off code.
It may not be what you are looking for, but it works well for me.
Edit: You will have to add an external temp sensor to feed the virtual thermostat if you go that way. Currently your AC does it's own thing once you use the virtual thermostat with Broadlink as a "setting sender" instead of as a controller. Many people prefer to sense the temperature away from the AC unit, for more accurate room temperature control, or use multiple sensors and the Average Temp app to feed a virtual thermostat.
I don't think this would work for me......my mini split is programmed to talk to my ecobee in hubitat. When the ecobee setting changes, the mini split mirrors with the same temp setting. So I woulld need to have the ability to set a specific temperature on the mini split.
A possible solution would be ditch the virtual thermostat.....no way to do a manual tweak in Hubitat, but still have hubitat sync the two units.....there is probably onlly a dozen codes I'd need to capture at that point.
I really would like to be able to have a hubitat dashboard tile with a thermostat though. But maybe not a realistic optoin with the Broadlink.
It's a chore to record all those codes but doable. I think it might be possible to synthesize the codes, too. I just asked my friendly clanker and it executed itself gladly on the Fujitsu.
If you have the codes, it should be possible to avoid complex conditionals by composing strings with variable substitution.
Those are indeed thoughts and I have not tested them.
Yeah, you have a totally different situation than I do, my mini split is IR only, and not smart in any way.
You could sync using other virtual devices to just send a number.
A Dimmer or Bulb Template with a virtual dimmer by sending codes based on level set, then you can use the slider to set temp within range. The level template will give you up and down arrows.
You can use number hub variable or variable connector and put it as an "input" on the dashboard, where you type in the temperature
