I've been doing smart home automation for about 2 years now, entirely through wifi using Alexa and Smart Life. I bought a Hubitat on prime day after a lot of research and trying my hand at IFTTT (Which really sucks) and ST (better than IFTTT, but still some deal breakers).
So, at the moment I have no Z-Wave or Zigbee devices. I have a Ring Alarm, over a dozen wifi outlets, a dozen or so wifi wall switches, and an extensive Wyze network of Cams, Sensors, and Bulbs.
I'm trying to get this all to work on Hubitat so I can really automate and control my home, while I work on learning how to hack the wifi devices that can be hacked to run directly from HE, and start replacing the ones that can't.
So, I'm trying to control wifi devices, which currently all work through the cloud, and I am really struggling. I've spent hours watching youtube videos and digging through the community, and I'm not finding any good resource for a work flow for really controlling wifi devices. What I have so far is a ton of virtual switches, buttons, lights, and sensors, which I am trying to control from a dashboard through Alexa and IFTTT, with very little success.
Issue #1 - IFTTT Issues
I'm trying to control wifi outlets and lights using Virtual Switches and IFTTT. 3 out of 5 times I click the virtual switch on my Dashboard and it triggers on the dashboard, but IFTTT shows no activity. 1 of the other 2 times it turns the item on then the item turns right back off, even though the virtual switch is still on. The final 1 of 5 seems to work, but it literally takes 10+ seconds. It seems to be the same for Off and On, so out of 10 clicks on the Virtual switch the light will come on and back off twice and I might get it to stay on once or twice and maybe turn back off if I'm lucky.
This also has issues going the other way. If I turn the light on/off with Alexa, at least 2 out of 3 times it doesn't trigger the IFTTT aplet, especially when turning the devices on, it seems to work 4 out of 5 times when turning devices off, but not when turning them on.
I've also had the issue where I turn the device on with Alexa, the IFTTT aplet runs, then a second later the light turns off. I look at IFTTT activity and it's showing that the Virtual switch turned on, then turned off, which caused the light to turn off, even though I didn't touch the virtual switch.
Issue #2 - Can't get Alexa to change things in HE
This one is pretty specific to Ring, as IFTTT works with Wyze and SmartLife. I set up an Alexa routine to turn on a virtual contact sensor when a Ring sensor is open, and another to turn it back off when a Ring sensor is closed. The routines are active, and I even tried manually calling them, but the sensor on the dashboard remained Closed the entire time. I also tried doing the same thing with Motion, and could not get it to toggle a motion sensor.
Any help in getting these things working would be much appreciated.
