Vesternet dimmer module
I currently use fibaro dimmer modules & they work very well with HE using a custom DH. However, I want to make a 3 way lighting circuit smart, and this would be much easier to do using vesternet dimmer module. Basically it allows the current switched live to be used as a manual switch, whereas I dont think you can do this with fibaro.
I was wondering if anyone has used the vesternet module with HE, and which DH they used. I did find reference to one on github. For my implementation, it is critical that I can distinguish between a programmed switch and a physical switch actions on the module. (the fibaro/DH does support this)
