I know this is probably simple and I can search around but I'm not really finding it. I'm, migrating a big system from Vera where I was a heavy Reactor user. I am trying to replicate the feature where I can have one set of actions for when a particular condition(s) is met and then another set when the same condition is no longer met. Playing with rule machine, I'm only seeing the ability to turn something on based on a trigger but not turn it back off when that trigger is no longer true.. or should it be a condition?
Do i need to make two separate rules for everything?
If you were comfortable creating automations in Reactor, why not continue using it? @toggledbits has created Multi-System-Reactor that supports multiple platforms, including Hubitat.
You'll have to run it on separate hardware, but even something like an RPi will be amply sufficient.
I have jumped around automation engines a few times after moving to Hubitat. Right now, 95% of my needs met by apps that run on Hubitat, particularly Rule Machine.
But Hubitat's strength is that it easily supports external automation engines, including MSR and Node-RED.
For sure... And I don't know that I am up for setting up another external device to do this. My rules are not overly complicated but they generally have and on and off action tied to the same condition's true or false status. I'm struggling with that here as it seems to me that I have to rewrite the conditions for both on and off.
I have two weather conditions that when true should trigger a virtual switch called Sunny Day. Using the rule, how do I toggle that virtual switch back to off when neither of those conditions are still met? (It is two or three conditions and it seems that I have to rewrite them all for the off too?)
Trigger:
Weather-1 is on
OR
Weather-2 is on
Conditions:
Weather-1 is off
Weather-2 is off
Actions:
On: Sunny Day
Wait for expression (Weather-1 is off AND Weather-2 is off)
Off: Sunny Day
These are actual term evaluations - as in contains "clear" or contains "partially cloudy". So for the Conditions, is there any way to call the inverse of those or do I have to write them both out again?
To be clear, you don't have to set any conditions (what you term as attributes) for your Trigger. You need them only for the body of the rule where you evaluate "state".
Actions:
IF (OpenWeatherMap-Alerts Weather Driver condition_text(Few clouds) contains Clear(F) AND OpenWeatherMap-Alerts Weather Driver condition_text(Few clouds) = partly-cloudy-day(F) [FALSE]) THEN
On: Sunny Day
ELSE
Off: Sunny Day
