I found an updated driver on Tosa68's GitHub.
I've ported it to Hubitat, and it IS working for me just fine.
My battery updates occur along with regular wake-ups in the device's event logs!!!
Posting here if anybody wants to use it.
NOTE 1:
I really do NOT know Groovy. I hear "groovy" and I think 70's!
NOTE 2:
The Toggle Wake Up Status button generates an error in the logs initially. You must let the device go through an update cycle at least once before it will no longer give the error. It doesn't stop the driver from working though, afaik.
* Everspring/Utilitech Water Sensor
* Everspring Flood Sensor ST812-2
* Utilitech Water Leak Detector TST01-1 (Lowe's)
* Author: tosa68
* Date: 2014-07-17
* ORIGINAL SOURCE: https://raw.githubusercontent.com/tosa68/tosaSmartThings/master/devicetypes/tosa68/utilitech-water-sensor.src/utilitech-water-sensor.groovy
* Ported to Hubitat by GatVlieg
* Version 0.8 (2016-11-02): changes to (hopefully) catch all WakeUpNotifications
* Version 0.9 (2017-03-07): "passive heartbeat"
* - i.e. option to report WakeUp in activity feed;
* - option to always report Battery status in activity feed
* (will report Battery changes regardless of this setting);
* - confirm WakeUpInterval change in activity feed
* Version 1.0 (2017-08-14): added capability "Sensor" and "Actuator" for ActionTiles compatiblity (thanks @moritzes)
* changed to multiAttributeTile layout (thanks @johnconstantelo)
* added "Woke Up" tile to toggle display between time of last wake up and elapsed time since last wake up
* Version 1.1 (2019-11-18): minor code clean up and update to GitHub
* Features:
* 1) Battery status updated during configure, at power up, and each wake up
* 2) User configurable Wake Up Interval
* Configure after initial association happens before userWakeUpInterval can be set,
* so device will start with default wake up interval of 3600 sec (1 hr).
* To set userWakeUpInterval, from the mobile app:
* 1) enter custom value in device preferences, then
* new interval will be set when device next wakes up
* OR
* 3) press 'configure' when the device is awake:
* - either just after initial association (within about 10min),
* - after power up (remove/reinsert batteries)
* Copyright 2014 Tony Saye
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
preferences {
// manufacturer default wake up is every hour; optionally increase for better battery life
input "userWakeUpInterval", "number", title: "Wake Up Interval (seconds)", description: "Default 3600 sec (60 sec - 194 days)", defaultValue: '3600', required: false, displayDuringSetup: true
input "alwaysShowWakeUp", "bool", title: "Report WakeUp", description: "Report when device wakes up in activity feed", required: true, displayDuringSetup: true
input "alwaysShowBattery", "bool", title: "Always Report Battery", description: "Report battery status in activity feed whether or not it has changed", required: true, displayDuringSetup: true
metadata {
definition (name: "Utilitech Water Sensor", namespace: "tosa68", author: "tony saye") {
capability "Water Sensor"
capability "Battery"
capability "Configuration"
capability "Sensor"
capability "Actuator"
command "toggleWakeUpStatus"
fingerprint deviceId: "0xA102", inClusters: "0x86,0x72,0x85,0x84,0x80,0x70,0x9C,0x20,0x71"
* simulator {
* status "dry": "command: 9C02, payload: 00 05 00 00 00"
* status "wet": "command: 9C02, payload: 00 05 FF 00 00"
* status "wakeup": "command: 8407, payload: "
* status "low batt alarm": "command: 7105, payload: 01 FF"
* status "battery <20%": new hubitat.zwave.Zwave().batteryV1.batteryReport(batteryLevel: 0xFF).incomingMessage()
* for (int i = 20; i <= 100; i += 10) {
* status "battery ${i}%": new hubitat.zwave.Zwave().batteryV1.batteryReport(batteryLevel: i).incomingMessage()
* tiles (scale:2) {
* multiAttributeTile(name:"water", type: "generic", width: 6, height: 4) {
* tileAttribute ("device.water", key: "PRIMARY_CONTROL") {
* attributeState "dry", label:'${name}', icon:"st.alarm.water.dry", backgroundColor:"#ffffff"
* attributeState "wet", label:'${name}', icon:"st.alarm.water.wet", backgroundColor:"#00a0dc"
* valueTile("battery", "device.battery", inactiveLabel: false, canChangeBackground: true, width: 2, height: 2) {
* state "battery", label:'${currentValue}%\nBattery', unit:"",
* backgroundColors:[
* [value: 19, color: "#BC2323"],
* [value: 20, color: "#D04E00"],
* [value: 30, color: "#D04E00"],
* [value: 40, color: "#DAC400"],
* [value: 41, color: "#79b821"]
* valueTile("wakeUpStatus", "device.wakeUpStatus", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
* state "wakeUpStatus", label:'${currentValue}', unit:"", action: "toggleWakeUpStatus"
* // green = #44b621; yellow = #f1d801; orange = #d04e00; red = #bc2323
* // attention orange = #e86d13; battery green = #79b821
* standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
* state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
* main "water"
* details(["water", "battery", "wakeUpStatus", "configure"])
log.debug "parse: $description"
def parsedZwEvent = zwave.parse(description, [0x9C: 1, 0x71: 1, 0x84: 2, 0x30: 1, 0x70: 1])
def result = []
if (parsedZwEvent) {
result = zwaveEvent(parsedZwEvent)
log.debug "Parsed ${parsedZwEvent} to ${result.inspect()}"
} else {
log.debug "Non-parsed event: ${description}"
updateStatus()
return result
def zwaveEvent(hubitat.zwave.commands.wakeupv2.WakeUpNotification cmd) {
// Appears that the Everspring/Utilitech water sensor responds to batteryGet, but not wakeUpNoMoreInformation(?)
/* Oct-2016: troubleshooting not getting wakeUpIntervalSet during WakeUpNotification
/ Was trying to only send wakeUpInterval if it was changed, but sensor didn't seem to be getting command
/ during wakeup; now sending wakeUpInterval and getting battery status for each wakeup period
/ Note: some wakeUp events still seem to be missed, perhaps due to SmartThings latency? But shouldn't be a big
/ deal if a wakeUp here or there are missed since we're only setting wakeUpInterval and getting battery
/ status.
//def result = [createEvent(descriptionText: "${device.displayName} woke up", isStateChange: false)]
def map = [:]
def result
map.descriptionText = "${device.displayName} woke up"
map.displayed = true
if (alwaysShowWakeUp) { map.isStateChange = true } // always report Wake Up events in activity feed
result = [createEvent(map)]
// If user has changed userWakeUpInterval, send the new interval to the device
/*def userWake = getUserWakeUp(userWakeUpInterval)
if (state.wakeUpInterval != userWake) {
state.wakeUpInterval = userWake
result << response("delay 200")
result << response(zwave.wakeUpV2.wakeUpIntervalSet(seconds:state.wakeUpInterval, nodeid:zwaveHubNodeId))
result << response(zwave.wakeUpV2.wakeUpIntervalGet())
// Always send wakeUpInterval and get battery status
state.wakeUpInterval = getUserWakeUp(userWakeUpInterval)
result << response(zwave.batteryV1.batteryGet())
state.lastWakeUp = now()
return result
def zwaveEvent(hubitat.zwave.commands.sensoralarmv1.SensorAlarmReport cmd) {
def map = [:]
if (cmd.sensorType == 0x05) {
map.name = "water"
map.value = cmd.sensorState ? "wet" : "dry"
map.descriptionText = "${device.displayName} is ${map.value}"
} else {
map.descriptionText = "${device.displayName}: ${cmd}"
createEvent(map)
def zwaveEvent(hubitat.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd) {
def map = [:]
map.name = "water"
map.value = cmd.sensorValue ? "wet" : "dry"
createEvent(map)
def zwaveEvent(hubitat.zwave.commands.alarmv1.AlarmReport cmd) {
def map = [:]
def result
if (cmd.alarmType == 1) {
if (cmd.alarmLevel == 0xFF) {
map.descriptionText = "${device.displayName} has a low battery alarm"
} else if (cmd.alarmLevel == 1) {
map.descriptionText = "${device.displayName} battery alarm level 1" // device sometimes returns alarmLevel 1,
map.displayed = false // but this appears to be an undocumented alarmLevel(?)
result << response(zwave.batteryV1.batteryGet()) // try to update battery status, but device doesn't seem to always respond
} else if (cmd.alarmType == 2 && cmd.alarmLevel == 1) {
map.descriptionText = "${device.displayName} powered up"
} else {
log.debug cmd
return result
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [ name: "battery", unit: "%" ]
if (cmd.batteryLevel == 0xFF) { // Special value for low battery alert
map.value = 10 // will display (and alarm in mobile app) as 10% battery remaining, even though it's really 1%-19% remaining
map.descriptionText = "${device.displayName} has a low battery"
} else {
map.value = cmd.batteryLevel
if (alwaysShowBattery) { map.isStateChange = true } // always report battery level in activity feed
createEvent(map)
def zwaveEvent(hubitat.zwave.commands.wakeupv2.WakeUpIntervalCapabilitiesReport cmd) {
def map = [ name: "defaultWakeUpInterval", unit: "seconds" ]
map.value = cmd.defaultWakeUpIntervalSeconds
state.defaultWakeUpInterval = cmd.defaultWakeUpIntervalSeconds
createEvent(map)
def zwaveEvent(hubitat.zwave.commands.wakeupv2.WakeUpIntervalReport cmd) {
def map = [ name: "reportedWakeUpInterval", unit: "seconds" ]
map.value = cmd.seconds
createEvent(map)
def zwaveEvent(hubitat.zwave.Command cmd) {
log.debug "COMMAND CLASS: ${cmd}"
createEvent(descriptionText: "Command not handled: ${cmd}")
def configure() {
delayBetween([
zwave.associationV2.associationSet(groupingIdentifier:1, nodeId:zwaveHubNodeId).format(),
zwave.wakeUpV2.wakeUpIntervalSet(seconds:state.wakeUpInterval, nodeid:zwaveHubNodeId).format(),
zwave.wakeUpV2.wakeUpIntervalGet().format(),
zwave.batteryV1.batteryGet().format()
], 200)
def toggleWakeUpStatus() {
state.toggleWakeUpStatus = state.toggleWakeUpStatus ? false : true
updateStatus()
private updateStatus(){
def currentInterval = now() - state.lastWakeUp
def minutesElapsed = (currentInterval/1000/60).toInteger()
def hoursElapsed = (currentInterval/1000/60/60).toInteger()
//def timeString = new Date().format("MM-dd-yy h:mm a", location.timeZone)
def today = new Date(now()).format("MM-dd-yy", location.timeZone)
def lastDay = new Date(state.lastWakeUp).format("MM-dd-yy", location.timeZone)
def lastTime = new Date(state.lastWakeUp).format("h:mm a", location.timeZone)
(lastDay == today) ? (lastTime = "Today\n" + lastTime) : (lastTime = lastDay + "\n" + lastTime)
String statusText = "Woke Up:\n"
if (state.toggleWakeUpStatus) {
statusText = statusText + (hoursElapsed ? hoursElapsed.toString() + " hours " : minutesElapsed.toString() + " minutes " ) + "ago"
} else {
statusText = statusText + lastTime
if (currentInterval.toInteger()/1000 > state.wakeUpInterval) {
state.missedWakeUp = (currentInterval.toInteger()/1000/state.wakeUpInterval).toInteger()
log.debug "current interval: " + currentInterval.toInteger()/1000 + "; wakeUpInterval: " + state.wakeUpInterval
log.debug "# missed wakeups: " + state.missedWakeUp
//log.debug statusText
sendEvent(name:"wakeUpStatus", value: statusText, displayed:false)
private getUserWakeUp(userWake) {
if (!userWake) { userWake = '3600' } // set default 1 hr if no user preference
// make sure user setting is within valid range for device
if (userWake.toInteger() < 60) { userWake = '60' } // 60 sec min
if (userWake.toInteger() > 16761600) { userWake = '16761600' } // 194 days max
* Ideally, would like to reassign userWakeUpInterval to min or max when needed,
* so it more obviously reflects in 'preferences' in the IDE and mobile app
* for the device. Referencing the preference on the RH side is ok, but
* haven't figured out how to reassign it on the LH side?
//userWakeUpInterval = userWake
return userWake.toInteger()
