Using Rule Machine to send POST to an https server with self-signed cert. How would I have the automation ignore the self signed cert?
This works going to a test http server but does not seem to work on the https server.
you would need to create your own http device driver or customize an pre-existing community http driver that wraps the httpPost(params) call with ignoreSSLIssues: true. Then you can use RM to automate that device.
Not quite what I am looking for. Although I have the ability to do this, I do not have the time. Would it be possible to have an option to select the "ignorSSLIssues" feature in the rule machine like the option in MakerAPI?
I would be curious to know what design you would implement. AFAIK it's not possible to return values from a custom action, unlike the "native RM" http calls, so no drop-in replacement is possible. If you're only looking to perform fire-and-forget calls then I second @sidjohn1 's suggestion - your favourite AI chatbot can generate that driver in seconds.
Must be possible but would require a UI change (thus additional complexity) and open the door to requests for multiple other options. RM has been pretty close to qualifying as abandonware the last year or so. You could try tagging staff or posting this in the feature request category.
I’m sure it is possible as a feature request. Hopefully it will get added to RM at the same time this RM bug gets fixed. I chose to find a work around, but it’s REALLY not elegant so it would be nice to have someone wait with me for fixes/features to be added to RM. Welcome to the club. ![]()
Absolutely! Do I need to request this feature? If so how do I go about doing so? I have a plan for a work around for now on my side so I can wait.
