Using Room Lighting with Modes
For some reason, when I activate a Room Lighting scheme that is then supposed to change the scheme based on mode changes, when the mode changes, the lights do not change. As best I can determine, the scheme is going inactive but I do not know why. Can anyone help with this?
It would help if you could show the app logs for the time when the mode change occurs. You can force mode changes from the Settings / Modes page, in order to test the app.
