Using RM to a EchoSpeaks command...?
I've got Echo Speak and now would like to create a virtual switch/button to send a Alexa connected device a voiceCmdAsText() Echo Speaks command.
I have limited experience in Rule Machine but I am pretty sure it can be done.
Any help would be appreciated :slight_smile:
The trigger would be your virtual button or switch. For the action, you should use "Run Custom Action", pick the Echo Speaks device, and then select the custom action (voiceCmdAsText()).
Thanks - worked exactly as I wanted it to.
