This is my first Tech Tip Post. I apologize if it's been posted in the incorrect category.
Not sure if this would interest anyone else, but if you want to integrate your âAmbient Weatherâ dashboard, here is how I did it. This just a shortcut to creating a template with multiple attributes. Iâm a ânoobâ and always looking for an easier way to do something that someone else has already done.
Start by creating a text (CSS) fileâŚ
After youâve created and uploaded the CSS file via âSettings -> File Managerâ, use the HTML âTile Template Generatorâ (to create a device to add your new imported attribute to) and âTile Template Device Managerâ (to associate the âhtml#â attribute youâve created with the device).
I called mine âWeatherHome.txtâ (you donât have to use the .TXT extension)
I was able to see find my weather station ID by clicking on the tabs at the top. When I did, it populated. I also checked other nearby weather stations on the Ambient Weather Network and was able to see others that shared their weather data.
Right at the moment, it isn't being shared. I just got it. It is a used Texas Weather Instruments WRL-25. I did not get a disc with the TWI Log program. I was able to find a copy of the TWI CAL program. I am able to access the information via a terminal program. I'm having problems getting the Weather Display program running. I thought I had it working, but it stopped displaying information. It will have the capability to share once I get it working. Until then, it is just trying to figure out everything related to this unit and Hubitat.
I hadn't thought about using it as a general purpose way to integrate other websites until @Eric.C.Miller mentioned it, but I added my WiFi VENSTAR ColorTouch today...
