My Z-Wave network becomes unresponsive after the C-8 Pro hub has been running for a while. I checked for ghosts and believe some of my Z-Wave devices flood the network and cause the issue. (I have 259 devices) For now, I plan to shut down and restart the hub, since the Z-Wave radio doesn't reset on a reboot alone. I am mostly remote and use a Wi-Fi switch to cycle power and restart the hub. This is difficult to automate. Since the hub is down, it can't restart itself. The main hub is in MESH with a C-7, which interfaces with Alexa and other remote services. I was using GROK BOT, but it turns out it can't control my Leviton outlet without a password. It's been able to shut down the hub from a cloud dashboard.
New Plan:
Create a rule on the C-8 to turn on a virtual switch on the C-7, then shut itself down using the Hub Information Monitor. Write a rule on the C-7 to wait 5 minutes, then power-cycle a Zigbee outlet that controls power to the C-8. The C-8 only has the Z-Wave radio on. I will turn on the Zigbee on the C-7 and buy a Zigbee outlet. I may see if I can control the Leviton switch with Matter, but i am thinking it is too old.
Am I on the right track?
